Hi
Does anyone guide me how to compile FreeRTOS for TC375, how to do I select BSP. Should I use Aurix workspace or ModusToolbox for compiling FreeRTOS. Can anyone provide me procedure.
UmaMahesh
AURIX
Hi, I am looking for supporting documents how to compile FreeRTOS for Aurix TC375, I am a registered user and I am looking for information which tool to be used on windows to compile FreeRTOS. If you can provide or link me to specific user manual it would be helpful. I using Modustoolbox v3.0 and Aurix Development tool v1.7.2 on windows 11
Hi umamahesh, so far the project is the only one for FreeRTOS with source code, and there is no further info provided. I will provide if we have in future. Thank you.
dw
Can you please link to the demo project of FreeRTOS for TC375 and can you tell me whether I should use modustoolbox or aurix workspace. I am confused which one to be used. Please help me
Hi, above link is for demo code but you should register myICP, and you could use ADS IDE to compile the demo code which is a free tool for evaluation. Modustoolbox is not used.
Hi
I downloaded the demo code and when build the project getting following errors
10:48:40 **** Incremental Build of configuration Default for project Auromotive_Gateway_24V_ETH_LWIP_HTTPD ****
make all
Cannot run program "make": Launching failed
Error: Program "make" not found in PATH
PATH=[C:/Infineon/AURIX-Studio-1.7.2//plugins/com.infineon.aurix.jre.win32.x86_64_1.7.2/jre/bin/server;C:/Infineon/AURIX-Studio-1.7.2//plugins/com.infineon.aurix.jre.win32.x86_64_1.7.2/jre/bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\umesh\AppData\Local\Microsoft\WindowsApps;;C:\Infineon\AURIX-Studio-1.7.2;]
10:48:40 Build Failed. 1 errors, 0 warnings. (took 66ms)
Is any settings to be changed for aurix workspace
Please use BIFACES to build, and you should select the compiler PATH in BIFACES. Also need myICP to download it.
Please check the following error in screenshot. Please help on this.
Select Compiler PATH is as following steps:
No such Tasking folder has been created under ProgramFiles
I am using windows 11, will BIFACES or AURIX have issues on Windows 11?
Hi, The Demo link is not accessible even after registering myICP, can someone share the code.
