AURIX™ Forum Discussions
User20089
Hello
I am implementing Queued SPI in slave mode on a TC23x, the transmit and receive interrupts are working. On a receive interrupt I load new data into the Tx FIFO (shift register) through DATA_ENTRY, which will be sent on the next clock.
I would like to "flush" the Tx FIFO on the slave side at the EoF or SLSI deselection, I cannot find a method to flush the TxFIFO. Is there a method, or do someone know of a workaround.
cwunder
You can reset the QSPI State machine and both the TXFIFO and RXFIFO by setting GLOBALCON.RESETS = 7
