Hello Team,
I am using TC375. I am performing voltage tests (Under voltage 4.7V for 5sec and Normal Voltage 13V for 15sec) in 30 loops. In some situation after entering 13V, the Flexray communication is not started or started with the delay (2s to 5s). But the CAN communication is started.
On further analysis we found that the Clock Correction Failed Counter is exceeding the “maximum without clock correction fatal” limit defined by SUCC3.WCF
The flexray is trying to recover multiple times, but it is not successful and it is unable to resynchronize with the bus.
Please refer to the attached snapshots and logs.
This is an high priority issue and needs immediate resolution
Aurix
@dw Your reply is empty. Do you want to say something?
I am developing flexray function of TC375. Could you please send me a routine of E_Ray module, or the reading materials about E_Ray module
Looking forward to your reply
