AURIX™ Forum Discussions
User18451
Hello Infineon Support Team,
We are currently working on a flexray driver for TC387 evaluation Kit. We are currently using the iLLD available in myInfineon.
Our test environment is
1. TC387 Evaluation Kit
2. Tasking Compiler
3. iLLD_1_0_1_9_0__TC38A
We integrated the driver in our systems. We observed the following.
1. We have done all the Init configuration as recommended.
4731.attach
2. The ERAY0_SUCC1.CMD is in 'RUN' state and not moving to “Normal Active “ or “Normal Passive” mode. All nodes and pins are configured correctly. But POCS is in "Integration Listen" state.
4732.attach
3. We could understand that iLLD drivers were not “Tested “. But can you please help us in understanding what could be the problem here?
4. Please share if you have any AppNotes which would help us in understanding the E-Ray driver.
Please let us know if you need any further information
R.Sreedhar
Joro
First reply posted Welcome!
Hi R.Sreedhar,
did you manage to get it working ?
thanks
BR
joro
