amlanij
I am new to the Infineon environment. I have built a code using BIFACES, and want to flash this code on TC299Tx board. Currently this is in development phase, so I can easily attach the board to the PC and can test the build.
Prudhvi_E
250 replies posted 100 solutions authored 25 likes received
Hello @amlanij ,
From the description, the question is not very clear. Could you please elaborate more ?
Is the board custom board or evaluation kit ? You can use MemTool for Flashing.
Prudhvi.
Prudhvi_E
Hello @amlanij ,
Prudhvi.
amlanij
Hi Prudhvi,
It is a custom board, What I want to do is flash the code in debug mode and read the registers and step through the code. I have a hex file ready using BIFACES, I will read about the MemTool.
Thank you,
Jay
