cha1pi
5 replies posted 5 questions asked 10 sign-ins
While trying to flash my TC397 kit , I get this every time. Is there some setting I need to change
"::Loading HEX file ..........
:⚠️ The given program file is trying to write on reserved memory addresses, which will be skipped."
TBencher
Level 6
Level 6
25 solutions authored 25 likes received 5 questions asked
if you did not actively try to put data on reserved memory areas, it seems you have the wrong project setup. Please start over again with a suitable setup.
TBencher
Di_W
Hi cha1pi,
Have you tried to use UDE starter to load .elf? Have you used Memtool to load .hex?
dw
TBencher
Level 6
Level 6
Hi dw,
I assume *.hex related to his post. I also assume ADS because this is always recommend if you start with the kits.
But let's wait what he'll say 😉
TBencher
cha1pi
This is in the Aurix Development studio. even When I import projects from examples here : AURIX_code_examples/code_examples at master · Infineon/AURIX_code_examples · GitHub , I end up getting the same warning. The code still runs on my board
TBencher
Level 6
Level 6
you should setup a clean project for your board. Then try to compile. No warnings should appear. Don't use the example projects directly. Then, put the example code -just the code- in. Check for dependencies.  Afterwards try to compile again.  As a result, you should not have this warning anymore.
TBencher
TBencher
Level 6
Level 6
Any news?
cha1pi
So I cleaned and rebuild the project, I do get the same warning while flashing. "Don't use the example projects directly. Then, put the example code -just the code- in" . Do you mean to start a new project and then copy the code contents or the code file from the examples to my new project?
Dependencies seems to be fine
TBencher
Level 6
Level 6
just the content. But even without it, your project should be compilable without any warnings.
TBencher
TBencher
Level 6
Level 6
Any news?
