06:47 AM
Sep 14, 2016
06:47 AM
I can't debug an example application through the Tricore free toolchain and the debugger showed some errors.
Error Messages
Message from component 'Tc2CoreTargIntf' :
Can't connect target !
Can't connect JTAG target
This problem occured after flashing Hello_Serial Example.
Everything is well before uploading this example application.
I can't debug any example anymore.
Hope you can help me on that ASAP.
Thanks In Advance.
Error Messages
Thanks In Advance.
03:15 AM
Nov 04, 2019
03:15 AM
Have you found a solution to this problem? I seem to get the same error but already while flashing a sample program to the board.
Thanks in advance
Best
Padma
Thanks in advance
Best
Padma
