Hello All,
I am using Aurix v1.7.2 and a demo Board AURIX TC3xx starter Kit.
I connect my demo board with the micro usb to my laptop usb.
I compiled a demo soft and try to flash it, I have an error "Drivers for the Infineon DAS debug probe not detected"....
I tried to install the latest DAS v7.3.7, and I have a message "Already installed th elatest DAS version 7.3.7".
I have checked and no DAS seems installed on my PC?! I have checked the regedit, and did not found DAS key.
I have reinstalled Aurix and still the same issue...
It seems some other person had same issue but I did not find a solution...
Can someone helop me?
Thansk in advance
- DAS AURIX
I have tried a lot of times,
1) Installed DAS 7.3.7
2) Clean registry by script
3) Reinstall DAS 7.3.7
It works.
Could you try to restart your Windows?
dw
Hi User90300,
First suggest to reinstall DAS v7.3.x.
Below script is to help clean the registry for DAS.
dw
Hi dw,
Thanks for your heilp, but I have already reinstall DAS v7.3.x and the Key mentionned in the mail does not exist in my registry...
I have already search DAS key in registry and did not found anything.
Do you have another suggest?
Hi User90300,
Could you please use the scrpt in above link? That will help to reinstall DAS.
dw
Hi dw,
I tried the script... same issue
Have you executed like above screenshot?
I have reinstalled DAS7.3 by above script.
dw
Yes I did!
But before I have checked, the key did not exist on my computer...
It works.
dw
Have your computer administrated by your Company's IT department?
If your registry is fully in your control?
dw
The DAS key was hide in my session.
IT find it with administrator privilege.
Now, I am able to install DAS 7.3.7.
Thanks dw
Could you please update if any success or failure? Thanks.
