AURIX™ Forum Discussions
FD_aurix
100 sign-ins 100 replies posted 5 solutions authored
Hi all
I'm new to Aurix, Just getting a demo board and trying to compile and re-download a demo SW. What tools shall I use to read the actual SW present on the demoboard and download a SW?
thanks
cwunder
25 likes received 25 solutions authored 100 sign-ins
AURIX Development Studio (ADS) will aslo download the code (erase/write the flash) when you debug the target (AppKit / TriBoard / Lite)
FD_aurix
Yes, I've seen but it seems a build in funcionality that I can't use as stand alone. There are some other tools available?
teoBits
100 replies posted 50 replies posted 25 replies posted
AURIX Development Studio also includes a separate flash tool for flashing only and avoid debugging:
4931.attach
By clicking this button it will build the active project and flash it into your device.
If you want to use this tool separately, you need to copy the software and its needed files and libraries into a separate folder, and then run the command "AurixFlasher.exe -hex "path to the .hex file"" or "AurixFlasher.exe -elf "path to the .elf file"" from the folder where you copied the tool.
Usually, you can find the tool in the ADS installation folder following "\plugins\com.infineon.aurix.tools_1.3.0\build_system\tools\AurixFlasher_v2.2.1.0"
FD_aurix
Hi All
One question About aurix flasher. Does it write the UCB section all the time if the UCB addresses are defined into the elf file?
teoBits
In AURIX TC3xx no, the currently released version only writes the software in program flash and skips the UCB.
