Jan 29, 2021
05:07 AM
Jan 29, 2021
05:07 AM
Hi all
I'm new to Aurix, Just getting a demo board and trying to compile and re-download a demo SW. What tools shall I use to read the actual SW present on the demoboard and download a SW?
thanks
thanks
Jan 29, 2021
07:45 AM
Jan 29, 2021
07:45 AM
Jan 31, 2021
09:44 AM
Jan 31, 2021
09:44 AM
AURIX Development Studio (ADS) will aslo download the code (erase/write the flash) when you debug the target (AppKit / TriBoard / Lite)
Feb 01, 2021
01:09 AM
Feb 01, 2021
01:09 AM
Yes, I've seen but it seems a build in funcionality that I can't use as stand alone. There are some other tools available?
Feb 02, 2021
02:04 AM
Feb 02, 2021
02:04 AM
AURIX Development Studio also includes a separate flash tool for flashing only and avoid debugging:
By clicking this button it will build the active project and flash it into your device.
If you want to use this tool separately, you need to copy the software and its needed files and libraries into a separate folder, and then run the command "AurixFlasher.exe -hex "path to the .hex file"" or "AurixFlasher.exe -elf "path to the .elf file"" from the folder where you copied the tool.
Usually, you can find the tool in the ADS installation folder following "\plugins\com.infineon.aurix.tools_1.3.0\build_system\tools\AurixFlasher_v2.2.1.0"
Dec 21, 2021
05:40 AM
Dec 21, 2021
05:40 AM
Hi All
One question About aurix flasher. Does it write the UCB section all the time if the UCB addresses are defined into the elf file?
Jan 10, 2022
02:37 AM
Jan 10, 2022
02:37 AM
In AURIX TC3xx no, the currently released version only writes the software in program flash and skips the UCB.
