Jan 10, 2023
04:11 AM
Jan 10, 2023
04:11 AM
Hi
I want to transmit some data over the RJ45 connector and read it on my pc.
Instead of using the Lwip stack for ethernet tx/rx, I want to use the GETH module and configure the PHY to transmit the data. Is there any example code for this ?
Labels
Aurix
09:47 PM
Jan 10, 2023
09:47 PM
Could you let us know if you are using the device TC3xx or TC2xx (eg: TC397, TC279)?
Are you using any evaluation kits from infineon or a custom board?
You can also try the "Ethernet_1_KIT_TC397_TFT" ADS(Aurix Development Studio) example.
Best Regards.
Jan 11, 2023
06:45 AM
Jan 11, 2023
06:45 AM
Hi
I am using Tc375 lite kit
The Ethernet_1_Kit is based on lwip right? I dont want to use lwip, instead just use the "geth_transmit" function say to transmit data
11:06 PM
Jan 15, 2023
11:06 PM
