Jan 31, 2023
12:46 AM
Jan 31, 2023
12:46 AM
I am using the TC399 evaluation board "KIT_A2G_TC399_5V_TRB".
If you verify the operation of the S/W with the Debugger and try to download it again with the Debugger, it will fail.
The RST LED on the evaluation board is lit.
Is it possible to reset the board to initial state?
01:02 AM
Jan 31, 2023
01:02 AM
How does the verified S/W make AURIX work?
Feb 01, 2023
03:55 AM
Feb 01, 2023
03:55 AM
Are you able to connect to the debugger and debug and only not able to program?
Aiswarya.
