AURIX™ Forum Discussions
pistons7
50 sign-ins 5 likes given First solution authored
I am using the TC399 evaluation board "KIT_A2G_TC399_5V_TRB".
If you verify the operation of the S/W with the Debugger and try to download it again with the Debugger, it will fail.
The RST LED on the evaluation board is lit.
Is it possible to reset the board to initial state?
NXTY_Ota
Distributor - NEXTY (Japan)
25 sign-ins 10 replies posted First like received
How does the verified S/W make AURIX work?
Aiswarya
25 solutions authored 50 replies posted 100 sign-ins
Are you able to connect to the debugger and debug and only not able to program?
Aiswarya.
