Jewook
First question asked Welcome!
Once it was bricked, the evaluation board JTAG can not be connected with port fail.
Is there any solution to make it get back to normal?
MoD
50 likes received 500 replies posted 100 solutions authored
If there is no more valid code in the device for HSM (because the HSM programm was erased) then you can only exchange the device. There is no possibility to recover the device. You can avoid such situtation only when you protect the code for HSM or disable the HSM before reprogramming.
MoD
Basil_Mathai
25 replies posted 5 solutions authored 50 sign-ins
Device is bricked. Please do replace the device and take precautions to avoid device lock up in future.
