AURIX™ Forum Discussions
Michael_Krueger
First reply posted First like given First question asked
I ordered the TC367 Starter Kit V2.0 with the TC3x7 AURIX evaluation board (V2.01). It is a socketed board. When I opened the package the micro (TC367) appears to be loose.
Is there a video showing how to socket the micro? Even a video for a different board, but same style socket would be helpful. I also want to verify the orientation of the micro. I see a dot in the bottom left corner but do not see any indicator on the physical socket.
I also looked for info in the "Infineon-TriBoardManual_TC3X71-UserManual-v02_01-EN.pdf" and could not find any discussion about the orientation or socketing. I apologize if I missed it.
I have attached a picture of how it arrived. As I said it is loose. If I turn the board upside-down the micro would fall out. I assume it should be latched down somehow.
Thanks for your help.
Michael
cwunder
25 likes received 25 solutions authored 100 sign-ins
It looks like you have it 180 degrees off. See this picture.
To seat the device simply push down on the sides of the socket and then the device will seat. Then slowly release it. The socket has two clamps on the two sides to hold the device in place.
cwunder
