Shafi96
50 sign-ins First solution authored 25 replies posted
Hi team,
We are working with AURIX TC397x. We are running the echo application which was given in examples, it is working fine. AURIX will start the server and client can access the terminal. We want to measure the speed of Ethernet of AURIX as both server and client.
How to measure the speed of ethernet server of AURIX using iperf?
My PC is connecting to AURIX server as client and can measure the speed using iperf tool, it is only about 27Kbytes/s, How to achieve 100Mb/s?
Help is most appreciated.
Shafi.
