Nov 18, 2020
10:58 PM
Nov 18, 2020
10:58 PM
I am trying to download a hex file using wiggler(JTAG)+memtool on a board made with AURIX 2G(SAK-TC397XP-256F300S BC)
If I add a hex file after connecting with the board, a warning occurs as shown in the picture attached below.
Why is the warning occurring?
Do I need additional settings? Or can I ignore the warning?
12:16 AM
Nov 19, 2020
12:16 AM
There some flash parts not enable which are part of your file. Maybe you must select DF_UCBS on FLASH/OTP - Memory Device and select Enable for this part. Maybe another device is the problem. If you will program also any UCB then make sure that the content is correct because with a wrong content for UCB you can destroy the device and it is no longer usable.
If you don't need to reprogram any UCB then you can ignore this warning.
