User21656
I am using TriCore Eclipse IDE v6.3r1 to develop my software on an Aurix TC23x.
The compilation goes well, but at link time, I have the following error:
"ltc E157: cannot find address space 3 for section ".zdata.Mk_k_data.MK_initTestData" (89)"
I don't understand where this error comes from ?
The MK_initTestData variable declaration/definition is implemented as following:
mk_uint32_t MK_initTestData = MK_INITTEST_VALUE;
(if I remove this variable, then the same error occurs on another variable, even if it is not initialized)
I attached the link script file to this message (it has been provided to me ; I just modified it slightly).
Any help would be appreciated
NeMa_4793301
Level 6
Level 6
10 likes received 10 solutions authored 5 solutions authored
Per Tasking's ctc_user_guide.pdf, zdata is __near data. Near data has to be in the first 16K of a segment.
Try making a group in the first 16K, and allocate zdata and zbss to that group.
User21656
Thank for the answer. one of my colleague just told me the same thing
Have you solved this problem? I also have the same problem and don't know how to solve it
