- Email to a Friend
I first tried to install :
Infineon-Memtool-DevelopmentTools-v05_00-EN.exe on my windows 10 PC (this installer has been successfully installed else where). After installation, when I first run it, I got pop up "Can't create Memtool user interface !".
Then I downloaded the latest: Infineon-Memtool-DevelopmentTools-v06_00-EN.exe which automatically install pre-requisites. Uninstall the previous version, then install the latest one. I got the same error once I tried to run it.
Please see attached and kindly advise.
- Email to a Friend
1. Could you let us know the device you intend to use?
2. Could you follow the below steps and let us know the behavior?
a) Uninstall all the components of Memtool.
b) Delete the files from %temp%(Run command).
c) Restart the system.
d) Install the Memtool by following the guideline from "Release Notes"
https://www.infineon.com/dgdl/Infineon-MemTool-Release-Notes-DevelopmentTools-v08_00-EN.pdf?fileId=5...
e) Restart the system.
f) Check the behavior.
Best Regards.
- Email to a Friend
Company Use
