Hi ,
I am working Bootloader for TC377 series , Bootloader code using EVADC Group10 (Pin P33.7) for sensing voltage levels
this is working as expected .But after jumping to Application code from bootloader, Application code has it own EVADC Initialization its Triggering TRAP. If Application runs independently (no bootloader code preset in flash) application EVADC
initialization is working as expected. Let me know if anything need to do with EVADC in bootloader code before jumping to Application?
Thank you in Advance.
Mahammad Nazeem S
The reason could be that the Init function/thread is lacking sufficient privileges to modify the critical registers of ADC. Please check the CPU mode or if the ENDINIT mechanism is properly unlocked in such scenario.
Prudhvi.
Hello Mahammad Nazeem,
Could you please share the details of the TRAP like Trap Class & TIN in the above scenario. Also, how are you jumping from Bootloader to Application ? Is it via a RESET ?
Prudhvi.
Hi Prudhi,
Thanks for your replay,
1. Below find the TRAP details that you are asking for,
trapWatch = (
tAddr = 0x8002E1BE,
tId = 3,
tClass = 0x4,
tCpu = 0)
tin = 0x3
2. from Bootloader to Application, not via RESET. below code snippet that used in bootloader code to jump to Application and let me know if you need more information
Mahammad Nazeem S
The Trap is set under following conditions:
Could you check which instruction in the ADC Init function of the Application is causing this Trap ? That should probably be a Register update instruction. Please check the ADC De-Init sequence executed in the Bootloader before jumping to the Application as shown in your image. The issue seems to be a Bus Error caused due to (Re-)initialization of certain critical registers related to ADC peripheral in the Application.
You may also refer to the examples of ADC Init in the Aurix code examples given below:
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples
Prudhvi.
Hi Prudhvi,
while returning the API "IfxEvadc_Adc_setGlobalConfigurations" triggering TRAP, and not sure which instruction its triggering. I am attaching the De-initialization code that I used in bootloader.
And In Tricore examples I could not find any De-init of EVADC code , please suggest me if my De-initialization code is not correct.
Thanks and regards
Mahammad Nazeem S
Prudhvi.
Hello nazeem,
Would you able to tell me which programmer you using to read and write bootloader ?
