AURIX™ Forum Discussions
nsyed
50 sign-ins First solution authored 25 sign-ins
I am using TC377 MCU, and trying to configure the EVADC in the following fashion.
Channels of ADC Group8 are logically divided into three different groups as shown below
  1. Group8 - CH2      -> This group/channel sampling has highest priority
  2. Group8 - CH3      -> This group/channel sampling has next highest priority
  3. Group8 - CH4-CH15 -> This group sampling has the lowest priority
Group8 - CH2         - Start of conversion shall be triggered based on PWM rising edge
Group8 - CH3         - Start of conversion shall be triggered based on different PWM's rising edge
Group8 - CH4-CH15    - Start of conversion for this group shall be triggered by SW
Currently, I can successfully configure and test each group individually, but when I integrate all three it does not work.
Any thoughts, on how I can accomplish this ?
Is there any example project which I can refer ?
Yuva
100 solutions authored 25 likes received 100 sign-ins
I request to discuss this topic with PDH or local sales as this is MCAL product which is licensed.
nsyed
Hello Folks,
Any thoughts on this question ?
nsyed
Dear Community Members,
Any feedback on this question ?
ScottW
First solution authored First like received 5 sign-ins
I'm afraid there isn't enough detail here to properly diagnose your issue. When you say, "it does not work," for instance, it would be helpful to know if you're getting results for any of the channels, and what you have done to determine that the triggering is not happening. If you can provide the code you used to configure the EVADC, that would be helpful as well.
nsyed
Hello Scott,
Below is my configuration, I am using MCAL for this configuration.  Can you please provide some guidance
nsyed
Hello Scott,
Any thoughts ? Your feedback will be greatly appreciated.
Jamber
25 replies posted 50 sign-ins First like received
Hi, nsyed
ADC not work are commonly caused by mistake trigger configuration, try a check.
Another reason is your result handling configuration, such as service request, different group priority are routed to some specific service request line, please reference MCAL user manual.
Or you can directly check the RES register in debugger to know whether it is really not work.
Jamber
Yuva
nsyed
Hello Yuva,
Who is PDH ? I tried to contact local sales to get some help, but most of the team here don't have expertize on MCAL.
Or is there any other platform where we should discuss MCAL related topics ? Let me know.
Yuva
You can find the details about PDH in the following link
https://www.infineon.com/cms/en/partner-network/microcontroller-partners/preferred-design-houses/
