FHeitor
First question asked Welcome!
Hello Support,
I'm not sure that I'm in the correct forum, but I need support.
I want to use the Group 9 channel 0 for EVADC and I've configured this group:
/* Enable queue 2 source */
adcGroupConf.arbiter.requestSlotQueue2Enabled = TRUE;
/* Enable the gate in "always" mode (no edge detection) */
adcGroupConf.queueRequest[2].triggerConfig.gatingMode = IfxEvadc_GatingMode_always;
/* Set the group 9 as master group */
adcGroupConf.master = IfxEvadc_GroupId_9;
/* Initialize the used group */
adcGroupConf.groupId = IfxEvadc_GroupId_9; /* Select the group 9 */
/* Apply the configuration to the group */
IfxEvadc_Adc_initGroup(&g_evadcGroup_G9, &adcGroupConf);
I get always as result value 4095.
I use the evaluation board TC366 Starter Kit and I've found now in the document Infineon-TriBoard_TC3X6-UserManual-v01_00-EN.pdf in page 42 the attached image. According this image we have no analog inputs for Group9.
Now I'm little bit confused whether I've a wrong configuration or group 9 doesn't work for EVADC.
Can you help me?
Fernando
MoD
5 likes given 250 sign-ins 25 likes received
Please check the corresponding User Manual Appendix for the used device where you find the connection:
For your case, P00.12 is set to input with pull-up after reset therefore, you read always 4095 as value. You should disable the digital logic on this pin to use as analog pin by setting corresponding bit in register P00_PDISC.
MoD
