i am using AurixDevStudio and following code to init EVADC.
As long as i use this opt. settings everything runs fine.
However, if i switch to these setting, the code gets stuck at
BR
Thomas
AURIX
The ADS code examples are non-productive reference purpose and are tested only with the default options. We recommend users to use the options comes as default and we cannot guarantee with the options other than those.
Prudhvi.
Hello Thomas,
We'll analyze this internally and provide you an update. Meantime, could you please let us know the reason for changing the default Optimization and Trade-off levels?
Is it possible to share the screenshot of exact point or line at which the code is getting struck? My understanding is if there's no delay added then the code is never running and got struck at the function you mentioned. Is it correct ?
Prudhvi.
Hej Prudhvi,
i have very tight real time req. that's is why i need optimize code.
It's seems to stuck in
BR
Thomas
Prudhvi.
