Hello.
I read in UM:
9.1.4.1
External Service Requests (ESRx)
The ESR pins can be used in various ways:
• ESR inputs can trigger a reset
• ESR outputs can provide a reset indication
• ESR inputs can trigger a trap request
• ESR pins can be used as general data I/O pins
• ESR inputs can trigger a wake-up from standby mode
And question is: ESR pins can be used as general data I/O pins? And if "yes", then "how"?
Aurix
Yes, ESRx pins can be configured and used as GPIO but each reset will reconfigure the settings for ESRx (e.g. ESR0 will be driven low during reset).
No, ESR0 and ESR1 could not be used as GPIO
Thank you, FD_aurix.
Why UM have this info?:
• ESR pins can be used as general data I/O pins.
Without this info all is correct. But this statement confuse me.
I was not aware about this functionality. You can refers to the UM 9.1.4.1.3 ESR Registers Checking for the IOCR OUT IN and OMR register.
Ok, I understand this functionality after reset. But how reconfigure ESR0 as GPIO? And what iLLD functions use for that? In third party device ESR0 used for reset one chip and I want reset this chip in application at any time as needed.
The register configuration to make ESR pins to function as GPIO is available in section 9.1.4.1.3 of User Manual part1, refer IOCR.
