ELF File generation with TASKING Compiler
VasantharajE
First question asked Welcome!
I am working on tc27x Project using TASKING Compiler. Could you help me please generate the .elf file using Cmake .
Kindly share Command for generate .elf file.
Thank you.
Prudhvi_E
250 replies posted 100 solutions authored 25 likes received
Please refer to TASKING User's guide that comes with each toolset version. You may check TASKING commands using "ltc" with different options that includes method to generate an elf file.
Prudhvi.
Prudhvi_E
Prudhvi.
