ECCs detection procedure in TC36x DLMU
SChafik
I'm having some difficulties regarding the procedure to use to detect the presence of ECCs in the DLMU0 and DLMU1 on AURIX TC36x. I can't find clearly in the reference manual which registers to use. Can anyone tell me how can I proceed ?
Thank you in advance.
cwunder
5 likes given 50 likes received 50 solutions authored
Sorry, I am not really clear on your question. For the SRAM ECC on DLMU0/1 you can use the MTU to enable it, then access this SRAM via the SSH (read/write). Then you can examine the MCi_RDBFLy registers to view both the data and ecc bits.
Thank you for the reply. To clarify my request, I am searching for a method to detect the presence of ECCs in the DLMU0/1 not to view the data and ecc bits. on the LMU module on tc29x, this MEMCON.RMWERR flag is set when reading a memory with ECCs present. For the tc36x we are trying to do the same on the DLMU0/1.
My question: is there a flag that is set when reading from the DLMU0/1 with ECCs present?
Thank you in advance for your help.
