Jan 20, 2020
03:02 AM
Jan 20, 2020
03:02 AM
Does the UART (ASCLIN) support hardware flow (CTS/RTS) control pins?
Bernie
#8042000 20420
Bernie
#8042000 20420
04:20 AM
Jan 20, 2020
04:20 AM
Hi Bernie,
Yes, some of the ASCLIN modules support optional CTS and RTS signals. Be sure to check the datasheet (or On-Chip Connections in the User's Manual) for the selected ASCLIN module that you are using that these pins are available on a port.
Mr. AURIX™
Mr. AURIX™
Jan 21, 2020
06:09 AM
Jan 21, 2020
06:09 AM
Hi Bernie,
In ASCLIN ASC mode (UART) ,we have standard ASC and High speed ASC mode for transmitting data at higher baud rates. For high speed ASC mode, we require Rx and Tx but also CTS and RTS signals i.e handshaking signals.
You can read further in chapter 18 (ASCLIN ) of user manual. And be careful while pin selection i.e. look out for shield buddy user manual.
Neeraj
Neeraj
