I am using the TC234LP MCU, which contains an HSM (ARM M3)core. I have enabled the HSM BOOT in UCB and downloaded "HSMDemo.hex" into the program. I plan to use DAS to connect to HSM via MiniWiggler. Is this possible?
Aurix
- das
- hsm
- miniwiggler
Help me...
Hi User20311. DAS is the driver for the miniWiggler, so in a generic sense, it supports HSM control. But the important part is software support - what compiler/debugger are you using? AURIX Development Studio does not support the HSM. Commercial compilers do, as a separate license option.
i use arm-none-eabi-gcc. .
I have generated the "HSMDemo.elf" file, so this has nothing to do with the compiler.
I use trace32 to debug HSM well. so I want to try MiniWiggler to debug HSM.
How to do it?
TKX!~·
You'd have to write something to have DAS configure the Cortex-M3 debug registers in the HSM. Not for the faint of heart.
By the way, DAS is just a server, it communicates with MiniWiggler via USB, and interacts with IDE (like eclipse) via TCP port, similar to Openocd
