I can't find any technical documentation about the attached board. Can you help to find it ?
AURIX
please register to MyICP. There you can find all Triboard documentations.
TBencher
Thank you for your reply but I already checked and I couldn't find the application manual, datasheet, etc.
Just a second.
I'll check this.
Ok. It is available.
You need to take the TC2X7 version.
Exist board in the MyICP has 80 pins but mine has 320 pins and also there are other differences.
no you have way more pins connected. The TC2X7 inside the schematic is actually divided into several symbols for power supply, analog input, GPIO, ... If you count all of them together you will end up with 292 pins what points actually to your package class (7).
TBencher
