AURIX™ Forum Discussions
User18303
in terms of memory access time in AURIX, what is the difference if variable is allocated at LMU (Local Memory Unit) vs CPU core’s memory?
Thanks and regards
Lina
#8042000 13198
User18237
Hi Lina,
LMU has hardware interconnection with CPU core via Shared Resource Interconnection (SRI). Therefore, memory variable access at CPU core via Data Scratch-Pad RAM (DSPR) is faster compared to LMU.
Mr. AURIX™
