Is it Possible to control Traction Inverter And Compressor Motor with Single Controller with ASIL D Level(Both PMSM motors)?
Share any related documents for reference.
Hi Narayana. The answer is far more complicated than a simple "yes". I would consider the following:
- Motor control generally takes just a fraction of the AURIX bandwidth, so supporting two is easily possible. I would consider freedom from interference and availability. Does a fault in handling one motor lead to a fault in the other? Is it okay if an overall microcontroller fault (uncorrectable RAM error, etc.) leads to shutting both motors down while the system recovers?
- For two independent, safety-critical sets of outputs, you'd need to choose the I/O pins very carefully, to avoid as many package-related common cause failures as possible.
- The microcontroller is just a small part of system safety argumentation, but its safety documentation is likely the longest because of the vast number of transistors and associated safety mechanisms. A wise customer once told me the microcontroller was 10% of the overall FIT budget for an ECU.
Hello @Narayana
Please look into the following for information on AURIX processors that may be suitable for your purpose:
You may find the documents in the product page under documents menu.
Any Application reference Data (With two PMSM Motor Applications)?
Hi Rupak,
Any Functional Safety issues will be there if we use the same controller for both PMSM motors.
