01:54 AM
Jun 23, 2016
01:54 AM
Hello everybody.
I wonder what exaclty is behind "Dedicated Emulation Device" term, for example TC1791ED.
What I should know about this, what main diffrent is to standard version.
Thank you.
Thank you.
07:45 AM
Jul 27, 2016
07:45 AM
Basically, the Emulation Devices have extra memory and features to support trace. So, if you have a debugger with a licence extension to support trace and an emulation device fitted to your target hardware then you can use this extended debug feature. There are other differences as well, but this is the main thing.
I hope this helps.
Dave
I hope this helps.
Dave
03:22 AM
Nov 16, 2016
03:22 AM
Dave, thank you for your answer.
Unfortunately from about Jun 23rd, 2016 I am not able to get TC1791ED from anywhere and this is real problem for me. Luckly or not I can get TC1791S-384 F200EP AB where in PMU1 is 1MB PFlash instead 2MB comparing to 512 version.
Can you please refer me to some documents that will give some more data about PMU0 and PMU1, will memory address be different in both IC?
Thank you.
Thank you.
08:02 AM
Dec 06, 2016
08:02 AM
The size of Data Access Overlay (OVC) is mainly different between PD version & ED version.
You can search User Manual with key word "Emulation".
