Jan 21, 2020
06:09 AM
Jan 21, 2020
06:09 AM
I configured can driver and i found its going to DET endless loop due to "CAN_E_TIMEOUT_DET" .
In the BSW static code (can.h) I see the value of "CAN_E_TIMEOUT_DET". In the comment section it says to refer the spec: * \trace SPEC-1702, SPEC-1401, SPEC-50568, SPEC-1568 */.
I checked the Autosar documents but i didn't find the above specs. Can you please suggest where can i find these specs.
Thanks in advance.
Thanks in advance.
