Hello everyone. I am currently working on a project including Tricore (for the first time). I was reading manuals and trainings. But I could not understand what is their purpose and generally when I should use DSPR and PSPR. I would be grateful if you could also give some examples. Many thanks for your time.
Aurix
These are the local CPU volatile memories, DSPR is for data storage and PSPR is for Program code. You can refer to sections 5.3.6.3 and 5.3.6.4 in the hardware user manual part 1 for details.
@Yuva Thank you. Your answer helped me.
