When we integrating new Application , system going to Trap ( showing Data Address Alignment Error ). What is the main root cause of this issue?
DEADD Value is 0x7000B9B3
eg. newvalue = (Appl_sample[0].variable->value) After this line system going to trap.
In the debugger showing that Appl_sample[0].variable = 0x7000B9B3
Additionally, data address alignment Error can happen address alignment is not followed, parameters in circular addressing is incorrect. You can refer core architecture manual for details.
please could you provide your setup? Which TC and toolchain do you use?
Best reagards,
TBencher
