hey guys
I am trying to implement the latest DSPLIB V9.2 using Aurix development studio,after following the guidence “AP32528_Getting_started_with_Aurix_DSPlib_v1.2.0”,and trying to build this project,i meet issue as below picture
but i can't find anywhere else redeclare this function,can anybody solve my problem
thanks!
AURIX
- DAPLIB
1. Add include paths as below window.
2.Modify the dsplib.h file line 163: #include "Assert.h" --> #include "Ifx_Assert.h"
dw
Please refer to DSPlib_0v91_Quick_Start_Guide.pdf for HighTec Free TriCore™ Entry Tool Chain installation. The ADS needs migration of the source code.
dw
Hi DW
yes, I have tried the DSPlib_0v91_testbench_TC39xB,and compile it success
but what if we want to integrate dsplib into our own project,we found that if we delete function “Ifx_firComplexF32” ,project can be built
in app note AP32528_V1.2,only following step should be done(we already do it), so could you please help test in your own ADS project and fix this bug?
many thanks!
dw
many thanks DW!
seems its solution for V9.1 DSPlib version,but it doesn't work for V9.2
To upgrade to version 9.2, please perform the following steps:
Add Asm and DSPlib to the Libraries of the XXX project in the ADS environment.
In the TASKING C/C++ Compiler, add the Preprocessing directives "IFX_TRICORE_TARGET=1" and "IFX_TARGET_TRICORE_APPLICATION_FRAMEWORK=1".
In the TASKING C/C++ Compiler, add the following include paths:
"${ProjDirPath}/Libraries/DSPlib/examples/inc"
"${ProjDirPath}/Libraries/Asm"
"${ProjDirPath}/Libraries/DSPlib/inc"
Clean the Debug folder in the XXX project.
Rebuild the XXX project.
In dsplib.h, modify the function definition after the struct definition as follows:
Change:
void Ifx_firComplexF32 (struct Ifx_firComplexF32State ); /!< complex FIR filter */
struct Ifx_firComplexF32State {...};
to:
Please note that the ellipsis "..." represents the contents of the definition, and for further information, please refer to the corresponding header file.
