I am using TC377's DSADC to sample Resolver's sin/cos signal, and I enabled the CIC3, FIR0, FIR1, OffsetComp, Integrator.
The initial value of CALFACTOR is configured as 1.0985449.
1. If initial calibration after reset is not used, the sampling result is same after everytime reset, it's Vin * 1.0985449;
2. If initial calibration after reset is used, the sampling result is different after everytime reset, and the CALFACTOR is different, too.
For a given sin wave with Vpp=3.27V, if initial calibration after reset is not used, the sampling result is 3.59V, no matter how many times it's reset.
For the same sin wave, if inital calibration after reset is used, the sampling result is random, sametimes it's 3.05V, and sametimes it's 3.33V.
DSADC result uncertain if initial calibration is used
ASUS
Aurix
- dsadc
Is there some one can help me? This problem confused me for a long time.
Best Regards
ASUS
These days I did some test.
1. DSADC and VADC sampled a same DC signal in a same pin at same time. The MOD is 20MHz, and the result of VADC is constly, but the result of DSADC is different every time after reset.
The result of DSADC div CalFactor is constly and closed to the result of VADC.
2. I changed the MOD freq from 20MHz to 40MHz, the problem is disappeared.
Freq (MHz) |
CIC Dec |
CIC Shift |
CorrMul Factor |
FIR0 Dec |
FIR1 Dec |
Intg |
Freq (Hz) |
Grp Delay(us) |
20 |
8 |
9 |
1.0985449 |
2 |
2 |
64 |
9765.625 |
63.2 |
40 |
32 |
15 |
1.0985449 |
2 |
1 |
64 |
9765.625 |
76 |
I can't understand that, according to datasheet, the MOD can work at freq from 16MHz to 40MHz, but why it works not normally at 20MHz?
Hi
I'm having a similar issue, Did you understand what was the root cause ?
Hi, FD
Unfortunately noboby answer me and I still don't know the reason now. I guess it may be relative with the "timing resolution". If "timing resolution" low, the module has low result precision. As a result if the freq is high, the result is accurate.
Best regard,
ASUS
