Feb 06, 2023
08:49 PM
Feb 06, 2023
08:49 PM
Hi Everyone,
Following the ADS (AURIX Developer Studio). I have configured EDSADC (TC38A) in singled ended mode using P004 as input. And I tried to obtain the result, but output value (raw adc value) is always 0xFFEA ~ 0xFFE3 and it is not varying even if the input signal is varied.
Can you please check the attached EDSADC driver initialization/configuration, especially EDSADC Pin configuration (which is not present in ADS Documentation). And please give me your feedback whether the initialization/configuration is correct or not.
EthanHunt.
05:53 AM
Feb 13, 2023
05:53 AM
Could you please confirm if you have configured the correct channelID?
Aiswarya.
