Hi all
I'd like to have some more information about the logic I should select the different demodulator stage register value. There are a lot of filters that need to be configured so if there is some guideline (or at worst some hints) it will be really appreciated.
Hi FD_aurix,
Please refer to the code example like :
They have showed you how to configure those parameters, for details register to you could check GLOBCFG, FCFGCx, GAINCORRx, GAINCALIx
AP32385_EDSADC_basics_v1_0
AP32445-Tutorial_TC3xx_EDSADC_Basic_hands-on_tutorial_for_resolver_carrier_cancelation_v1.1.0
AP32459-Tutorial_TC3xx EDSADC_Configuration_for_Resolver_Application_v1.0.4
AP32554-Tutorial_TC3xx_EDSADC_Advanced_Tutorial_For_Resolver_Carrier_Cancelation_v1.1.0
AP32561-Tutorial_TC3xx_SiMIc_with_EDSADC_v1.0.2
You could register myICP for above application notes.
dw
Thanks for your reply. Do you have some sources also on how to configure the modulator parameters? like the GainFactor, cic shift, calibration Factor etc?
Br
Francesco
Hi FD_aurix,
