AURIX™ Forum Discussions
Dana
First question asked Welcome!
I want to save data in retention RAM.
I moved the retention RAM data from DSPR to DLMU, but after Lbist(cold reset) also DLMU is lost.
I updated the PROCONRAM, LMUINSEL to value 1. After Lbist, DLMU is keeping the data, but because the LMU is not initialized I have Ram error and Register error.
If I want to initialize it I also have  errors because I want to access uninitialized memory.
Yuva
100 solutions authored 25 likes received 100 sign-ins
I assume you are using Standby RAM for this, provide the exact region used. I am not sure why PROCONRAM, LMUINSEL to value 1 are configured, this clears the RAM and will not retain the data. Also, check if  PMSWSTAT2.STBYRAM,  PMSWCR0. STBYRAMSEL and  PMSWSTAT2.STBYRAM bits are configured correctly.
Yuva
