I want to save data in retention RAM.
I moved the retention RAM data from DSPR to DLMU, but after Lbist(cold reset) also DLMU is lost.
I updated the PROCONRAM, LMUINSEL to value 1. After Lbist, DLMU is keeping the data, but because the LMU is not initialized I have Ram error and Register error.
If I want to initialize it I also have errors because I want to access uninitialized memory.
I assume you are using Standby RAM for this, provide the exact region used. I am not sure why PROCONRAM, LMUINSEL to value 1 are configured, this clears the RAM and will not retain the data. Also, check if PMSWSTAT2.STBYRAM, PMSWCR0. STBYRAMSEL and PMSWSTAT2.STBYRAM bits are configured correctly.
