AurixFlasher - DAS::Error: Device reset could not be performed.
Overall time: 732 ms
AurixFlasher Exit Status: Fail
What does this error means? The code for reading single channel through ADC is able to flash. But this error occurred when I tried to flash the code to read multiple input voltage through ADC. The code have 0 error, but can't flash. How to solve this issue?
It's not a Hardware issue since I can flash other programs.
Could you check the below thread?
https://community.infineon.com/t5/AURIX/DAS-Error-Device-reset-could-not-be-performed/td-p/343615
Best Regards.
Thank you for your reply.
I checked that solution before I posted this error.
It's not a hardware error. I have several codes running on the microcontroller TC233lp and some doesn't flash and gives this error. So it is software error. Do you have any idea what causes the error?
