Apr 06, 2022
05:18 AM
Apr 06, 2022
05:18 AM
AurixFlasher - DAS::Error: Device reset could not be performed.
Overall time: 1286 ms
AurixFlasher Exit Status: fail
Flashing failed
what is the meaning of the error? How to solve it.
06:01 PM
Apr 09, 2022
06:01 PM
Please measure the reset pin to check if it has waveform.
Reset pull-up: After releasing reset on the target board, the reset has to be
deactivated within 200µs after the tool releases the pin. Therefore ensure that the
reset pin pull-up on the target board has a low enough value to deactivate the reset.
Otherwise the “DAS halt after reset” function may not work or the device is not even
recognized.
06:01 PM
Apr 09, 2022
06:01 PM
recognized.
