03:25 AM
Feb 03, 2017
03:25 AM
I am using Aurix Kit TC 297. I want to program it using 10-pin DAP miniwiggler. I have latest version 6.0.0 DAS server installed on my windows machine.
Now when I connect the board with miniwiggler and try to connect it on the HighTech Development Platform (TriCore Eclipse) it gives me the following error messages:
Message from component 'Tc2CoreTargIntf' :
Can't connect target !
Can't connect JTAG target
Message from component 'UDEDebugServer' :
Unable to establish connection . To correct the situation, check configuration file entries and try again.
I am tried to setup the Target Interface by using various given options. But still I am not able to connect the target with my Eclipse.
I want to dump my code on the Aurix Kit.
Can anyone please help me to solve this issue.
Thanks in advance.
Divya
Thanks in advance.
Divya
12:20 AM
Feb 04, 2017
12:20 AM
I tried the following steps:
1. In DAS device scanner, I started the UDAS server.
2. Then connected the AURIX KIT TC297 with miniwiggler and connected the miniwigglet to PC.
3. Clicked "Start Client" option on DAS Device Scanner.
But it shows me follwing message:
How do I solve the "DEVICE_ACCESS" error?
Quick help will be appreciated.
Divya
Divya
May 16, 2017
10:16 AM
May 16, 2017
10:16 AM
Hi Divya.
this error is for because the DAS cannot identify your Kit still.can you try connect to your kit in ASC Bootloader mode?
may be your configuration is wrong??
04:32 AM
Jan 07, 2018
04:32 AM
Hello:
I have also encountered the same problem. Have you ever solved the problem?How did you do to solve this?
Thank u
Thank u
