AURIX™ Forum Discussions
User20052
Hi All,
I'm running a background task, which is just a simple increment:
while(1){
counter++
I see that the runtime of the loop to increase counter to a fixed value heavily jitters.
Assembler code looks OK, there is no optimization. So I think the AURIX architecture does some prediction or optimization. Am I right?
Is there any option to switch the optimization off? I need a predictable runtime.
Many thanks!
Aitschebeet
NeMa_4793301
Level 6
Level 6
How much jitter is "heavily"? The AURIX TriCore CPU does do some speculative fetching, but in most cases, that only results in ~30 ns of variation. Otherwise, AURIX latency is generally very predictable.
Do you have interrupts enabled? Could a periodic interrupt be throwing things off?
User20052
Hey UC_wrangler,
Thanks for your reply. Finally, I observed that the debug information was just wrong.
The AURIX studio integrated debugger is really messy. :mad: It very often shows wrong variable values.
Aitschebeet
