AURIX™ Forum Discussions
User17740
First like received
Hi all,
Are there any recommendations for which crystal to be used with AURIX™ ?
Kind regards
Bernie
#8042000 21146
User18237
Hi Bernie,
There is no special crystal recommendation. All typical crystals on the market in the specified frequency range should run with AURIX™. The crystal specifications can be found in the datasheet. An additional Application Note is available to explain fundamentals.
See:
https://www.infineon.com/dgdl/Infineon-AP56002_Crystal_Oscillator_Basics-AN-v01_00-EN.pdf?fileId=554...
Mr. AURIX™
