Geoff
5 sign-ins First question asked Welcome!
Hello All,
Currently we are developing Autosar based OBC software on TC364 MCU
software has close loop control for PFC(power factor correction)
I would like to know if Infineon provide ready-to-use library with respect to control system
compatible with TC364 MCU
e.g.
PI controller
PID controller
FOC related
    Clark transformation
    park transformation
    inverse Clark transformation
    inverse park transformation
sin
cos
atan2..
Thanks in advanced.
Geoff
Prudhvi_E
250 replies posted 100 solutions authored 25 likes received
There is no library to cover all your use cases, but you may follow the path in your ADS example to see certain math functions implemented: <Project_Name>\Libraries\Service\CpuGeneric\SysSe\Math
For example: EDSADC_1_KIT_TC375_LK\Libraries\Service\CpuGeneric\SysSe\Math
If you're using the AURIX TC3xx Motor Control App Kit, you can follow the instructions below to get access to Firmware:
https://www.infineon.com/dgdl/Infineon-AURIX_TC3xx_Motor_Control_Application_Kit_TOOL_Instructions_E...
Prudhvi.
Prudhvi_E
Prudhvi.
