Consultation on the number of updates to SOTA configuration parameters
Anony
25 replies posted 10 questions asked 50 sign-ins
           I saw the erase/program cycles of UCB on the Datasheet as marked in the following figure, which can be understood as the UCB area can only be erased/program 100 times?
I saw that the configuration parameters for the SOTA (Software over the Air) function are in UCB_ SWAP_ ORIG and UCB_ SWAP_ In the COPY area, if I need to configure the A/B Bank every time after I refresh the APP software, does that mean I can only use the SOTA function to refresh the APP software 100 times?
Di_W
Since we use a round-robin approach to update SWAP, you can write SWAP 16 times before erasing the UCB. This means you can use a total of 16 * 100 cycles for SOTA.
Di_W
