AURIX™ Forum Discussions
hi!
Can anyone update me on the steps I need to take to connect and flash a code on TC234 LP using the Tasking Integrated Debugger.Last time I tried and the device got locked.Have downloaded the DAS server also.Any kind of help will be appreciated.
srividya
µC_Wrangler
100 sign-ins 25 likes received 25 solutions authored
Make sure at least one boot mode header is set:
Properties / C/C++ Build / Memory / Boot Mode Headers
Boot Mode Header configuration: Generate Boot Mode Header
Hardware configuration start-up mode: Internal start from Flash
Mode selection by HWCFG pins: unchecked
