I'm trying to enable debug and flash protection. The OCDS ,DBGIFLCK and RPRO bits set.
Upon receiving the password , I'm calling disable protection command sequence for UCB_DBG for disabling protection and I'm verifying PRODISDBG this bit for password match . If we have received correct password
1)whether the hardware itself will clear DBGIFLCK and RPRO or manually developer needs to clear it
2)After successful disable of protection for UCB_DBG , does it disable for UCB_PFLASH as well or any specific command sequence need to be followed to disable flash protection.
J Gopinadh
Aurix
- debug protection
Hi @Gopi,
1. Load page and write burst commands are used to write data into UCBs. The PROCONDBG or PROCONPF registers are loaded during start-up (or reset) from the UCBs.
2. As mentioned in the AURIX_TC3xx_Part1-UserManual, the password protection of only the selected UCB (if this UCB offers this feature) is temporarily disabled by setting DMU_HF_PROTECT.PRODISx (with “x” indicating the Pflash, Dflash or DBG UCB) or DMU_HF_PROTECT.SRT when all the passwords PW0–PW7 match their configured values in the corresponding UCB.
The DBGIFLCK & RPRO bits are not cleared automatically.
1. DMU_HF_PROCONDBG.DBGIFLCK and HF_PROCONPF.RPRO bits are read-only for the software.
2. RPRO depends on UCB configuration. You can refer to "PFLASH and DFLASH Read Protection" in AURIXTC3XX_ts_part1_V2.5.1.pdf
Best Regards.
1) I'm setting DMU_HF_PROCONDBG.DBGIFLCK and HF_PROCONPF.RPRO bits using Flash commands like load page, write burst. Is this a proper way of setting these bits?
2)Since these bits are set, after receiving correct password whether hardware will clear these bits(DBGIFLCK & RPRO) automatically?
Hi @Gopi,
Please let us know if your query is resolved.
We will wait for 3 days and then lock this thread. In case your problem is not resolved, please create a new thread and we will be happy to help.
Hi karishma shaik,
Please lock the thread, i was still working on this i guess it will take more time.
i'll create new thread for further queries.
J Gopinadh.
